'99 Headlight switch w/fogs
Hey guys, first off, I don't own an F150... I actually own a 1999 Taurus and I am trying to find out some information about the 1999 style of headlight switch on the F150s with foglights... I installed some aftermarket foglights to my Taurus and as some of you may know, no Taurus from that era came with factory foglights... Instead of drilling a big hole in my dash to accomodate the switch, I've been told that the F150 switches are the exact same as the Taurus switches just with different faceplates... After some preliminary research this seems to be true, they are the exact same size, and have the exact same wire harness sockets on them...
Now, what I actually came here to ask was: which connectors actually carry the foglight power? By comparing some bad pictures of the F150 switches, and looking at the back of my own switch, they both seem to have 3 narrow connectors in each socket at the top, and 2 thick connectors and 1 narrow at the bottom... Now, my question, is the foglight power carried via either of these connections, or is there another socket that I'm missing? If anyone could tell me which connector does this/if they have a diagram it would really help me out alot...
My hope is that I can get an F150 switch, hook up my foglights to it and pop my Taurus faceplate on it... I may have to drill a small hole in the faceplate so you can see the lil LED indicator and paint the little "pull for foglights" diagram on it... I know that some of the guys on the Taurus board know everything there is to know about those cars, and I'm hoping alot of you know the same about the F150 here!
