Trim Removal Question
I posted this in the Super Crew section but didn't get any responses, so I thought I would try for a wider exposure. Of course, it may be as simple as no one has tried to take this part apart - but here goes:
"... I was trying to remove the map light assembly from the headliner in my '06 screw. I have a sun roof, so I don't have the information center, just a little unit with two map lights and the switch that operates the sun roof. I was trying to pop this unit out of the headliner so I could tap in to the switched power going to the sun roof. I want to hard wire a backup camera display that I have mounted on the corner of my rear view mirror. I realize I was probably being over cautious, trying not to break anything, but I couldn't get the unit to pop out. Is there any hidden catch, or do I just need to pry on it with a flat tool (putty knife, etc.) till it pops loose? Any "been there, done that" info would be greatly appreciated. TIA"
If anyone else has any actual experience, please step in.
Thanks again.
Good to hear it worked for ya. I had the same problem when my map bulbs burnt out...I was amazed at how hard i had to pull on it, but having taken off and put back on just about every other peice of trim in the interior, i found that most of the peices are fastened with those metal tabs.
