Anyone Else Had This Problem...
Old Mar 11, 2008 | 07:18 PM
jiFord's Avatar
I have a 98 F150 and the whole back window seal needs to be relaced. I just wanted to see if anyone else has had this problem.
Old Mar 11, 2008 | 07:24 PM
kansasflareside's Avatar
i dont know what seal you are talking about, but on my '97, the seals for the sliding middle section dissapeared. now when i wash my truck, the interior gets wet too.
Old Mar 12, 2008 | 01:03 PM
jiFord's Avatar
You have to take the third brake light off to see the seal.
Old Mar 12, 2008 | 01:19 PM
Les22's Avatar
a lot of 97's and 98's had this problem. I took mine to the dealer 3x's before they finally had a auto glass company replace the window and the seal
Old Mar 12, 2008 | 06:28 PM
Bent6's Avatar
25 Year Member
If it's a factory slider, the frame cracks, and the rear window needs to be replaced. It's been a while since I've seen it here, but there was a rash of failures documented here when these trucks were newer.
Old Mar 12, 2008 | 08:25 PM
jiFord's Avatar
You know wut now that you mention it the plastic around the rear slider is cracked but I dont think thats where the water is comin in cause i checked that. If that plastic around the slider is cracked should I get it replaced?
Old Mar 13, 2008 | 08:08 AM
Les22's Avatar
If you have full glass coverage, see if your insurance company will replace the window. Tell them the plastic is cracked to get the whole window-including the seal replaced.
If you tell them the window simply leaks, they may not cover the replacement
