Passenger Door Panel
Old Jan 6, 2008 | 02:39 PM
clee1052's Avatar
I am having a problem with my electric locks. The Passenger side will not work. How do you take off the inside door panel to a 2001 F-150 Extended Cab
Chris
Old Jan 6, 2008 | 09:53 PM
JMC's Avatar
JMC
25 Year Member
Pull off the pillar trim on the door. The door handle trim must be removed. if you look closely there is a notch in the trim towards the front that you can use to pry it off with. Pry the front off to release the clip end them pull it towards the front. If you have electric windows pry up on the switch panel and it will pop out of the clips. If you have a window crank pull off the cover and remove the screw then pull off the crank. SUPERCABThere is a screw behind the door latch and on behind the door pillar cover that you removed. Remove the two screws. Pull the door panel up towards the roof and it should slide out of the slots. If you have the courtesy lamps turn the bulb in the door panel ¼ turn to release it. Careful it will be hot from having the door open all this time. Disconnect the harness and you are done. SUPERCREW Has 4 screws. One behind the door latch cover, one behind the window switch cover and two along the bottom of the panel.
JMC
