Dash bulbs out
Old Dec 21, 2007 | 01:58 PM
Camarothatcould's Avatar
Dash bulbs out
I have quite a few dash bulbs out and the gauges ar very dim and I cannot read them well at night. I know just about the whole dash has to come apart, but any hints or How-To's?
thanks
Old Dec 23, 2007 | 06:36 PM
I12AV82's Avatar
I dunno about 98, but the 99's had an issue with the solder on the back of the gauge cluster if I remember correctly - does your 98 have a digital or old round style odometer?
Old Dec 23, 2007 | 11:02 PM
non-digi. old school roller odom.
Old Dec 23, 2007 | 11:19 PM
quicktsi's Avatar
Does it have a shift indicator in the cluster. Not sure if they do, but on my old 01 Ranger it had the shift indicator in the cluster. If it does, the hardest part is getting the line disconnected that moves the indicator. On my Ranger once the cluster was out, it used the simple bulbs that just twist in and out. I was able to get the bulbs at the local Oreilly's.
Old Dec 24, 2007 | 01:45 AM
I12AV82's Avatar
This won't be affected by the issues I had with my 99, back to square one
I'm not familiar with the backlight system for this vehicle (maybe you can just change a bulb/fuse/whatever), but would it be cost effective to replace the entire cluster? I had the lights go out entirely on my 99, but the culprit was a bad fuse.
Old Dec 24, 2007 | 01:56 AM
replace all the bulbs while you are in there, you dont want to have to do it twice. shoot me an email and i can give you instructions for 03 dash which should be all the same as yours
Old Dec 24, 2007 | 03:58 AM
jbrew's Avatar
The 98 is pretty easy. You take the obvious dash components off to get at it . The gear indicator is prolly the trickiest to disconnect until you do it once. Theres three plugs in back of the cluster to disconnect.
You can test each bulb with a 1.5volt continuity tester - that will illuminate the dash bulb itself to test.
Most of the problems I had was contact problems. Steel wool and a fine brass wire brush cleaned them right up..
Old Dec 24, 2007 | 11:34 AM
So they are just a bunch of little bulbs?
Old Dec 24, 2007 | 11:41 AM
yea bulb is about 1/4" across should be 8 in there i think
Old Dec 24, 2007 | 12:30 PM
My dash setup
Old Dec 24, 2007 | 12:56 PM
clean your shift lever
Old Dec 24, 2007 | 01:35 PM
its been like that for three years
Old Dec 24, 2007 | 01:53 PM
jbrew's Avatar
Yea, there's 8 dash light bulbs, those would be the larger type. The rest are the smaller fault light, 4x4, seatbelt etc bulbs.. There's 2 grounds behind the drivers side kickpanel..
Old Dec 24, 2007 | 02:52 PM
Just an AfroZone or Advance part?
Old Dec 24, 2007 | 03:12 PM
jbrew's Avatar
Yea , any place should carry the bulbs - Auto Zone had mine..
