Water in the cab ( Help)
Old Nov 18, 2007 | 04:43 PM
nickbrumaghim's Avatar
I have a 04 super cab F-150 FX4. I purchased the truck with 12,500 on the odometer and it now has about 25k. During a routine cleaning I notice about an inch of water pooled up under the rear seat, on the passenger side. I removed the plastic trim that separates the carpet from the door jamb. This exposed a channel that the wiring harness runs trough. The entire channel had filled with water. If this is a common problem and some one could steer me in the right direction it would be greatly appreciated. Other wise I will just be pulling out the seats and carpet in hopes that the problem is obvious. This occured from normal driving on wet roads in the Pacific NW. Thanks in advance!
Old Nov 18, 2007 | 05:20 PM
TRITON_2002's Avatar
There are usually extra holes drilled in that channel and should be plugged if not used, check for any unplugged holes. It could also be leaking down from the door seal, so check that. A plugged up A/C drain usually gets the front passenger floor wet, but you might check that too.
Old Nov 18, 2007 | 08:26 PM
jrp22554's Avatar
some folks also have problems with their rear windows leaking and also the there have been issues with 3rd brake lights leaking
I believe that Ford had TSB's or recalls on this
do a search under the 2004+ forum
Old Nov 19, 2007 | 03:10 PM
Unhappy
Hey thank you guys for the information. I think the problem is comming from the front passenger area and saturating the back as my drive way is on a incline. I gonna buck up and pull out the seats and carpet.
Old Nov 27, 2007 | 08:37 PM
f-150sport03's Avatar
I have this problem-- anybody know how to fix it other than the repair shop?
Thanks.
Old Dec 2, 2007 | 01:17 PM
tito11304's Avatar
third tail light
check the foam gasket on the cargo light. mine was bent out of shape and let water in that pooled under the passenger side rear seat. all i did was take light assembly off with a screw driver realign gasket to proper position and screw back on the assembly.
Old Dec 2, 2007 | 08:43 PM
bluesupercrew05's Avatar
Just throw a tarp over it
