How To Remove Window Crank Handle
Old Nov 15, 2007 | 11:17 PM
waloro's Avatar
2001 F150 without power windows, I would like to know how to remove the window crank handle?
Old Nov 16, 2007 | 01:01 AM
Zaairman's Avatar
You've gotta buy a special tool from the auto parts store. It's like $6.
Old Nov 16, 2007 | 03:50 AM
DRJ's Avatar
DRJ
I sometimes just use a 45 angle pick to get to the clip that retains the handle onto the crank. Just push in the door panel and take a look between the panel and crank, you'll see either a gold colored or silver colored clip, if its the round end, stick in the 45 and pull it out gently...DONT LOSE IT!!
But there is a special tool u can use as previously stated, I just like using a 45. good luck!
Old Nov 16, 2007 | 12:07 PM
zziggy's Avatar
Now hear is the truth about your ford's window cranks.
The Pic explains it all. and saves me 1,000 words.
Old Nov 16, 2007 | 02:06 PM
DRJ's Avatar
DRJ
o chet I thought 97-03 f150's had the clip
Old Nov 24, 2007 | 11:48 AM
05'ThumpinSTX's Avatar
Be carfull not to strip the bolt. I stripped the **** outta it in my old 95' F150 and had to cut the bolt. Just use the right tool and dont use the wrong size allen wrench like me...
