Lightning steering wheel swap
I have a 2002 Lightning steering wheel with the cruise buttons but no airbag to go in my 2003 Lariat. The lightning airbag cover is different than the standard F150 but is the airbag itself? Anyone have the part number on the lightning airbag? anything else I should know about swapping it in place of the standard? Thanks in advance!
-Zac-
-Zac-
-Zac-
-Zac-
Airbag should be the same, but I wouldn't mess with it, unless you really know what you're doing, one wrong wire and BOOM
It plugs in. Not like splicing the wires together or something. If it is the same one then all that has to be done is removed the standard F150 cover, plug it in and mount it? I can do that
I don't know if you've had an airbag deploy in your face, but its not really fun.
Sure, it should be plug and play, I'm just saying, what if the wiring is messed up inside the airbag where you can't see it......Murphey's law.....
Originally Posted by t-rev
hes saying that anything that can go wrong, will go wrong.
Originally Posted by MmmBuckles
just pull the airbag fuse before you start working on it
