Arm Rest Removal
Old Oct 7, 2007 | 02:39 PM
arsenalgunner's Avatar
Arm Rest Removal
Couldn't find this on a quick search...Some of the lights under my power window and door lock switches have gone out. How do I remove the arm rest on the driver's side so that I can get access?
Old Oct 7, 2007 | 04:33 PM
Dallasstars10's Avatar
I believe that you have to take the whole door panel off. But more people will chime in with correct respones!!
Old Oct 7, 2007 | 06:23 PM
JRVicHammer's Avatar
Just use a small pry bar (screw driver) and pop open the control console. You may have to remove the trim around the door handle first by inserting a small screw driver in the slot above the door handle and press down and pull out the plastic cover. Then remove the two bolts behind the cover.
Old Oct 7, 2007 | 11:38 PM
Thanks a million, jjr! Those pictures are great. I definitely owe you one.
Old Oct 7, 2007 | 11:42 PM
cdnance's Avatar
this is probably the best illustrated how to i have seen. very nice
Old Oct 9, 2007 | 08:58 PM
Let me know if you are able to make the lights for your switches work again. The lights for both of the front window switches on my truck are out. I haven't had time to take my armrest apart yet. I think there are loose connections because occasionally one of the switches will light up temporarily.
Old Oct 10, 2007 | 08:05 PM
The problem is with the solder points on the illumination board. Requires solder on either side of the resistor for all non-working lights. Bigger job than I thought it would be, but not horrible if you've used a soldering iron before.
Old Oct 10, 2007 | 10:23 PM
Unfortunately, I have not used a soldering iron before. Oh well....I guess I will just let them go. I certainly don't want to pay for the dealer to fix/replace it.
Old Oct 11, 2007 | 10:12 PM
JJR,
If you don't want to mess with a soldering iron, you can buy the whole piece from Tasca on ebay for $35.
