Power window switch
Old Aug 26, 2007 | 01:48 PM
Doug Raymond's Avatar
Power window switch
The driver side switch is bad/broken. What is the aprox. location of the clips for the door panel or what is the actual access to the switches? This is a 2001 F-150.All tricks and help apreciated.
Old Aug 26, 2007 | 09:27 PM
Big Red P225's Avatar
The panel that holds the switches is separate fromt he door panel. You can just remove that part. Lift the front edge, it is clipeed tot he door panel. The rear edge has a tongue that fits under the arm rest. You shouldn't need any tools to pull up the switch plate.
Old Aug 27, 2007 | 02:12 PM
Thanks,I was messing with it today and it came off easily. Now to locate a switch I quess there is an aftermarket available. Again Thanks for the help,Red
Old Aug 27, 2007 | 08:54 PM
www.fordpartsonline.com has the left door window switch for $70, lower cost than the dealer. Otherwise try a salvage yard. There are old 150's at everyone.
