ORDINARY MAINTENANCE of Alcantara®
Old Jun 12, 2007 | 03:16 PM
Dbl G's Avatar
In order to preserve the beauty of your upholstery, excessively vigorous cleaning of accumulated dirt should be avoided. It is therefore recommended that regular cleaning is carried out. Avoid rubbing too strongly. The use of steam machines is not recommended.
Daily cleaning
It is sufficient to dust the fabric using a soft brush, a dry cloth, or
a vacuum cleaner.
Weekly cleaning
After dusting, run a lightly damp white cotton cloth over them. Avoid the use of printed absorbent cloths/papers as they can release ink onto the fabric.
Yearly cleaning
It is possible to clean Alcantara®, by using specific products listed in the web-site www.alcantara.it in the section furniture/maintenance. In the absence of the above-mentioned products, please follow the instructions below: dust the fabric with care; dampen a soft cloth or a sponge in clean water, wring it thoroughly and run it over the whole Alcantara® fabric, making sure not to wet it excessively; rinse the cloth or sponge and repeat as necessary. Leave to dry (overnight) Once dried, in order to restore the fabric, brush it delicately with a soft bristle brush.
GENERAL WASHING INSTRUCTIONS
Alcantara® must not be bleached with chlorine. If necessary, Alcantara® can be ironed, making sure that a white cloth is put between the iron and the product. The base of the iron must not reach a temperature higher than 110°C. In case of dry cleaning, trichloroethylene must not be used and direct contact with steam machines must be avoided. The use of the “spray extraction machine” is allowed only at low temperature. For the cleaning of non-removable upholstery follow the instructions given in the section “yearly cleaning”.
GENERAL INSTRUCTIONS FOR STAIN REMOVAL
In the case of localized stains, and when the specific products for the cleaning of Alcantara® are not available, (a list of such products is available on the web-site www.alcantara.it in the section furnishing/maintenance), the cleaning of the upholstery should only be done in accordance with the following instructions:
• Intervene immediately (within 30 minutes) and begin treating the stain from the outside edge into the center in order to avoid the stain spreading.
• Never pour a cleaning product directly onto the Alcantara® fabric.
• Before intervening, remove any of the substance that has fallen on the upholstery. In case of thick materials (yogurt, jam, etc.) with a spoon or a plastic spatula, in case of liquid materials with non-printed absorbent paper or a sponge.
• Avoid rubbing to prevent the stain from spreading or going deep into the fabric.
• Use a white cloth or a well wrung sponge for the removal of the stains.
• If you use a sponge, rinse it in clean water and wring it well between each wipe.
Water-soluble stains
It is recommended, depending on the type of stain, that you should use water, lemon juice, or pure ethyl alcohol (from liquors) and follow the instructions below.
Fruit juice, jam, jelly, syrup, ketchup: Use lukewarm water, rinse by dabbing with clean water.
Blood, egg, excrement, urine: Use cold water; avoid warm water because it makes these substances coagulate, rinse by dabbing with clean water.
Liquors, alcoholic beverages, wine, beer, coke and tea: Use lukewarm water; if the color mark remains, treat it with lemon juice and then rinse it well.
Copying pencil, cocoa, chocolate, pastry with cream or chocolate, ice-cream, mustard: Use lukewarm water; rinse by dabbing with clean water.
Vinegar, hair gel, tomato sauce, coffee with sugar: Use lemon juice and then wipe with lukewarm water rinse by dabbing with clean water.
Stains non soluble in water
It is recommended, depending on the type of stain, that you use water, lemon juice or pure ethyl alcohol (from liquors) and follow the instructions below.
Lipstick, foundation, mascara, eye-shadow, perfume, shoe polish, oil and grease in general, grass stains and felt tips in general (including the indelible kind): Rub with ethyl alcohol, then with water and rinse. For grass stains and felt tips, which are quite difficult to remove, especially on light colors, it is necessary to intervene as soon as possible in order to prevent them from becoming too “dry”.
Chewing-gum and wax: Put a plastic bag full of ice on the stain; when the material becomes hard remove the pieces and then treat with ethyl alcohol.
Resistant stains
Repeat the above described treatments as often as necessary. Even stains that are not soluble in water often require to be treated afterwards with water.
Old stains of unknown origin
First of all treat with lukewarm water, then rinse by dabbing them with clean water. If you see that the stain begins to dissolve with water, repeat the treatment as often as necessary. Let it dry and, if necessary treat with ethyl alcohol.
