Help! Squeak, dash dis-assembly
Old Nov 29, 2006 | 08:46 AM
boznian2's Avatar
I have the worlds most irratating squeak coming from my passenger side dash area. Imagine fingernails on a chalk board, but in very short duration bursts - sometimes 3 or 4 times a second. It seems to be coming from inside the dash, behind the airbag.
There is a long oval trim piece on the top of the dash which I think just has the little snap-locks for removal. Does the airbag cover come off the same way? Is there anything I need to know before tearing into that space? Any ideas?
This is an '03 SuperCrew King Ranch.
Thanks!
Old Nov 29, 2006 | 03:29 PM
frobird's Avatar
Make sure to disconnect the battery so you don't set off the airbag by accident. That's about all I can recommend.
Old Nov 29, 2006 | 03:37 PM
mattadams's Avatar
As I recall (though I've never disassembled mine to that point) that you actually have to take the dash partially apart to "safely" take that cover piece off.
Old Dec 10, 2006 | 06:02 PM
TODD141's Avatar
Try this link it might help
http://my.voyager.net/~sscully/F-150...50_Exp_002.doc
