Problem with heater
Old Dec 15, 2005 | 11:25 PM
bigtimepf's Avatar
Problem with heater
97 f150 My heater and air only blows out of defrost no matter what setting. Does anyone know whats wrong?
Old Dec 16, 2005 | 03:14 PM
tl3demon's Avatar
Depending on the set up of the system. On the manual systems cables somtimes break the gromets that hold to the controller or the door or also the lever it self binds or breaks. Now say if the controller was electric the motor could have seized then just leaving in defrost. You will need to start at the ac controller and follow cable and Etc. Personally it sounds like a popped cable or a bad controller
Old Dec 16, 2005 | 07:19 PM
bigtimepf's Avatar
I forgot to tell you that when it started It would be blowing right through the dash vents like it is supposed to, but when my RPMs went up the defrost would kick on.
Old Dec 17, 2005 | 09:09 AM
lvista's Avatar
I had the same problem with my '97 about 4 years ago. I would have to dig out the receipt but I think it was a vacuum motor that had to be replaced.
Old Dec 18, 2005 | 06:12 PM
bigtimepf's Avatar
did you do it yourself or did you take it in? If so where is it located?
