Squeaky Headliner.....Sounds like plastic ??
Old Jun 18, 2001 | 07:41 AM
GLADESTEEN's Avatar
Post Squeaky Headliner.....Sounds like plastic ??
When traveling down the road I hear this annoying noise coming from the headliner bouncing up and down. It sounds like the plastic inside is scratching when the headliner moves up and down slightly....Does anyone know what I'm talking about or have a solution for this problem??
It's driving me nutty!
Thanks,
Glade
------------------2001 Lariat
Green/Tan
4x4 Supercab
5.4L, Class III
Offroad pkg :-)
Mods:
Bug deflector (so far)
[This message has been edited by GLADESTEEN (edited 06-19-2001).]
Old Jun 18, 2001 | 09:22 AM
BlueFlareside's Avatar
Post
I am not sure but here is a friendly suggestion. You may want to make smaller images in your signature. Combined the two images are 375KB, which is almost a 1/3 of a MEG!! These images really bog down those of us on dial-ups.
For example, the image in my signature is two images spliced together into one image and is only 35KB.
Just a friendly suggestion...I am not trying to be the signature police.
Hope you find your answer.
‘98 F-150 XLT SuperCab Flareside, Auto, 4.6L, 4X2, 3.55 LS, 6-CD changer, Moonlight Blue with tan interior, Captains Chairs
Mods:Window tint, Extang Classic Platinum Tonno, Lund Interceptor bug deflector, Wizard Superwhite Bulbs, Pendaliner bedliner, Expedition center console, Airaid FIPK System
My F-150 Page
Expedition Console How-to
Old Jun 19, 2001 | 05:48 AM
GLADESTEEN's Avatar
Post
[QUOTE]Originally posted by BlueFlareside:
[/QUOT
Sorry Blue,
Didn't realise they were that big. I will open up photo editor and shrink em down a few.
Thanks for the input :-)
Mark
Old Jun 19, 2001 | 07:01 PM
Shark99's Avatar
Post
There are only a "couple" things other than the headliner that touch the roof. Check to make sure your overhead is tight. (if you dont have a sunroof) You will need to remove the long screw above the mirror, and then open the reward most door and using a screwdrive pop loose the two halves(where the two colors meet) once you pull that down, there are two screws in the front of the black half, make sure they are tight, and make sure the foam pad on the rear half isnt your culprit. check to make sure the screws holding your light are tight (take off cover) check all the plugs in the rear of the headliner, and the 'hangers' make sure everthing is tight. If this dosent seem to do it, your headliner is probably rubbing on the roof (if it is the headliner making the noise)
2000 XLT Silver 5.4L SC 4X4 ORP 157"wb Ford Floormats, MudFlaps, Cabin Air Filter, lighted emblems, lighted interior door handles(all 4) Chrome Grill (4x2 style), Diamondplate bed caps, Pro-Tech tool box, Air Box mod, Muth Heated Signal Mirrors, Custom Gauge Pod-(water temp, trans temp)
Perma-cool 8" Electric Trans Cooler Fan, 2.02" Radiator, 16" Derale cooling fan, Superchip (flipchip), Map lights in overhead, tinted windows, back up lights, soundproofed cab.
Old Jun 19, 2001 | 07:14 PM
Post
No problem...just thought that I would help those of us that are modem challenged!
Old Jun 20, 2001 | 06:10 AM
GLADESTEEN's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Shark99:
</font>
Thanks Shark!
I do have the moonroof and have checked everything I can think of to isolate this noise. It may seem trivial to some, but I just payed 30K+ for the truck and want it perfecto
I'm going to see a service advisor and take him for a spin today I think. Hopefully we get it fixed!
Thanks again!
Glade
Old Jul 18, 2004 | 07:56 PM
bvfd10's Avatar
Glade, Did you find out what it was ? I have it on my 04 Screw also. It comes and goes. Does it over bumpy town streets and also if you "push up" quickly on the dome light. Then other times its gone. Anyone else ?
Old Mar 6, 2005 | 09:33 PM
andygee's Avatar
Did you ever figure this out? I'm having the same problem on my 04 truck and the service dept has taken a look at it supposedly but can't find any problem with it. I dont' have a sunroof. The sound comes from right around where my visor touches the headliner.
Andy
