Anyone else have a problem with this?
Old Jun 13, 2001 | 01:04 PM
Qub3d's Avatar
Question Anyone else have a problem with this?
Just curious but in my truck it seem's like my rear view mirror is kind of low... it cut's off my visibility to the right of me out the front window. Half the time I have to crouch down to see if there is anyone at the intersection waiting to cross in front of me. I have my seat tilted a bit... I don't like to tilt it too much because then I get tired and that's not good I was thinking of just ripping it out and using my side view's but then I figured that I could probably just buy some window glue and remount it a bit higher...
'97 F-150 2X4 XLT Compustar alarm\remote starter K&N Air filter Rain away on the window's =)
Old Jun 13, 2001 | 01:12 PM
Cowboy-Up's Avatar
Post
I have the same problem. I am tall enough that I can look over the top, but mostly just look around it. It is a pain in the A$$ but I just dont worry to much about it.
Old Jun 13, 2001 | 01:31 PM
SilverFlareSide's Avatar
Cool
I just move the mirror up as far as it will go.
Old Jun 14, 2001 | 12:16 AM
sundog7's Avatar
Post
Ditto. That's what I did, too. Push that mirror stalk up high as it'll go, then readjust the mirror. Improved visual area for me!
Old Jun 14, 2001 | 12:28 AM
RAMBO97's Avatar
Cool
Can't say I have ever noticed, but I will now that it was brought to my attention.
'97 F150 XLT XCab, 4x4, Stepside, Black, 4.6L
Fiberglass Box Cover,
Bug Deflector, GTS Tailight Covers, Ford Factory Running Boards,
(2) 10" XTant subs w\ MTX amp (really pounds!!), Lifted Rear Seats 1" So The Subs Fit Under, Factory 6 Disc Changer, And One Cute Blonde In The Passanger Seat!!!
Pickup's Better Half: '68 Ford Galaxy 500, 2dr, Hardtop, Fastback
Old Jul 3, 2001 | 12:39 PM
hmustang's Avatar
I have the same problem as mine gets in the way at times.
Old Jul 4, 2001 | 06:34 PM
MotorcycleMan's Avatar
Thumbs up
I just undid the mounting screw and rised it as much has I could. Worked for me. Now I just leave the screw a little loose and take it off as I need to.
Old Jul 12, 2002 | 07:38 PM
Zinc-Zag's Avatar
Re: Anyone else have a problem with this?
I am interested in the CompuSTAR alarm. With the pager and all. Does anyone knwo what I should expect to pay for this?
What is MSRP? I think it's about $750.00US
What have other people paid?
Any problems for those who may have bought it?
I was just quoted 950 from a local isntaller. Seemed very high to me.
Thanks.
/tg
Old Jul 12, 2002 | 11:08 PM
Y2K 7700 4x4's Avatar
Since you have two outside mirrors, simply remove the darned inside RV mirror and you'll wonder how you ever tolerated the thing in the first place (this suggestion void if you constantly exceed the speed limit and have your eyes glued to the rear looking for red/white dome lights -- in which case the mirror is right where you need it).
Old Jul 13, 2002 | 11:43 AM
J-150's Avatar
these things are just glued to the window, so talk to an auto glass place to see how hard it is to remove and re-glue higher up the windshield.
Old Jul 13, 2002 | 09:53 PM
Or...
...buy a new 'thingy' and glue it above the one now on your window -- since your mirror will be in line with that old one, only your window cleaner (if you drive in New York) or the birds (if you live in Michigan) will know there are two on the glass.
Old Jul 14, 2002 | 11:13 AM
Wino's Avatar
my old truck was like that. took it to auto glass shop. about ten minutes. mounted up higher. no prob. it drove me freaking nuts before. they just take of the mirror. and hold the tab with vise grips. heat it up pops right off. reglue and i was on my way.
Old Jul 14, 2002 | 11:20 PM
SSCULLY's Avatar
Same problem here
Took it off the night I got home from the dealer, and tossed it in the tub of stock parts that go back on when I get rid of the truck.
I do this with every truck I get.
When I drove a semi I got used to not having it, and have never used once since.
