Power Window motor seems to be dying
Old Jan 13, 2001 | 08:16 PM
DGreen's Avatar
Post Power Window motor seems to be dying
Anyone noticed that their driver's side power window motor seems to struggle when opening the window???
The same thing is happening in my girlfriend's mustang. Also, right after the window opens, there is a loud click coming from the fuse box area.
2000 F150 XLT 4.6L V8 Auto, SuperCab, Torreador Red Metallic, Magnaflow Cat-Back Exhaust, K&N Drop-in, 265/75/R16 Futura Mud Terrains, Ford Bedliner, Tinted Windows, Steel Horse Billet Grill, Fabtech 3.5" Spindles, 2" rear blocks, Fabtech Performance Shocks
www.geocities.com/y2kf150
Old Jan 13, 2001 | 08:55 PM
ke4kfs's Avatar
Post
I had the same problem with my truck. I was able to solve my problem by lowering the window and carefully spraying a small amount of silicone spray lubricant into the entire window channel. Don't spray too much, or it will make a mess on the edge of your window.
White 2000 F-150 4x4 Lariat SuperCab with 5.4, Tow Pkg., 3.55 w/LS, 6-Disc, Tan Leather Captains
Old Jan 14, 2001 | 02:39 AM
DGreen's Avatar
Post
I have a bottle, I'll try it tomorrow. Thanks!
Old Jan 14, 2001 | 03:21 AM
Nitrox's Avatar
Post
The drivers side rocker switch for the power windows has two positions. If you press it lightly it's position one; if you press it firm or all the way down it's position two, which is to automatically roll the window all the way down.
The click that your hearing is the relay cutting the power to the window motor when it reaches the bottom.
Hope this helps ...
Nitrox
[This message has been edited by Nitrox (edited 01-14-2001).]
