Lether Steering Wheel
Old Feb 23, 2005 | 07:27 PM
whitsettj's Avatar
I have a leather steering wheel. How do I remove the black dirt on the wheel? Leather cleaner doesnt seem to work. Help. Thank you.
Old Feb 24, 2005 | 01:41 AM
Serge's Avatar
Are you sure it is dirt that is on your wheel? Sometimes with leather stearing wheels (at least some of the older ones I have seen) that have seen alot of use, a fine top layer of leather can wear off and it looks darker underneath. If it is acturally some kind of dirt try the leather cleaner again with a bit more elbow grease, and maybe a bit more abrrasive cloth. make sure that after, you use a new dry cloth to wipe off as much leather cleaner as possible or next time you go to pull a u-turn your hand might slide and you could be headed for the ditch!
Old Feb 24, 2005 | 06:17 AM
jhogan's Avatar
You may also want to try just some good hot water and a terry cloth. If that doesn't work Murphy's oil soap works very well at both cleaning and conditioning.
Old Feb 27, 2005 | 09:15 PM
Reloader's Avatar
Meguiars Gold Class leather cleaner and conditioner took all the black gunk off my steering wheel on my 02 Lariat Scab.Try it, it works.
Old Feb 27, 2005 | 09:27 PM
RockyJSquirrel's Avatar
For heavy stains you can also try saddle soap (available at most shoe or boot stores) . Then follow up with your leather conditioner/ cleaner such as Meguier's.
An old-timer told me how to use the leather conditioner. He said to rub it in with my fingers like suntan lotion, and work it in real well. Let it soak in for an hour and then wipe off the excess with a terry towel.
Old Feb 27, 2005 | 11:34 PM
Rockpick's Avatar
Moderator &
From properautocare.com
The Myth Of Saddle Soap
In the late 1800's the final tanning of leather required the talents of a "currier". This craftsman took the tanned but brittle hide and worked oils into it until the desired flexibility was obtained. This process was called fatliquoring. The fatliquor of choice was an emulsion of oil in soap. This "saddle soap" was not used as a cleaner. It was a softening conditioner.
In fact, saddle soap is a very poor cleaner. It must first dissolve its own oils, limiting its capacity to dissolve dirt and oils in the leather. Saddle soap is also inherently alkaline but alkalinity is damaging to leather. Another problem arises during application. Most saddle soaps instruct the user to work the lather into the leather. Since loosened dirt is suspended in the lather, it is pushed back into the leather's pores.
Saddle soaps have long been replaced in tanneries by modern emulsions which penetrate, soften and condition with greater ease and stability. the popular myth of saddle soap as a cleaner however persists as modern folklore.
Was that old-timer me? LOL! I've been applying conditioner for years with my hands. My point was that I didn't want to waste the conditioner by leaving it in an applicator or cloth used for applying the product... It works VERY well.
RP
