Wet Carpet
Old Oct 4, 2004 | 11:36 AM
msharris16's Avatar
Unhappy Wet Carpet
I have a 04 F150 Supercrew and the carpet from the passenger rear door to the front door is wet. I have no idea were it is coming from any thoughts? It is going back to the dealer on 10/07 but justing wondering if any similiar problems
Thank You in advance.
Old Oct 7, 2004 | 10:06 PM
japickar's Avatar
I know its not the same truck, but when I had this problem in my 97, it turned out to be a faulty back glass that the dealer replaced at no charge. That was when the truck was less than a year old.
Old Oct 21, 2004 | 09:52 AM
msharris16's Avatar
Cause of wet carpet
brought back to dealer and they found that a plug inside the front passenger side cowl had come lose. they resealed it and put it back in no problems since.
Old Nov 18, 2004 | 01:22 PM
jag72's Avatar
1998 F-250 light duty
My rear back window also leaks when ever it rains or I wash the car. It's the original window, It seems to be getting worse. Wondering if it's a recall and would be covered by the dealer?
Old Nov 18, 2004 | 01:35 PM
J-150's Avatar
Re: 1998 F-250 light duty
solid or sliding rear window? The sliding rera windows do leak and have been discussed here.
A solid rear window probably just needs a new seal.
Old Nov 18, 2004 | 07:16 PM
jag72's Avatar
rear window leak
Its the slider, it looks like the headliner,sits, and panelling need to be taken out in order to reseal. A lot of work. Wondering if any recalls from the dealer
Old Nov 19, 2004 | 12:13 PM
J-150's Avatar
Re: rear window leak
not sure if it was a TSB or not, but do a search on leaking sliders. From what I remember there was a fix.
Old Nov 20, 2004 | 09:13 AM
Rockpick's Avatar
Moderator &
Here's the HOW TO that I wrote several moons ago...
