passanger seat recline stuck
Old May 18, 2004 | 05:55 PM
Hortguy's Avatar
I've searched all over and can't find the answer, but I'm sure someone else has had the problem. The recline handle on the passanger side seat seems to stick after I use the release lever to tip the seat forward. The seat always latches and the recline always seems to work fine as long as I don't tip the seat forward. Once I've done that, I have to really work the lever to get the recline adjustment to release. I took the thing apart several months ago and cleaned it and put fresh lithium on it and everything worked fine until now. Anyone know the problem or do I just need to lube it from time to time?
Mike
Old May 18, 2004 | 08:14 PM
J-150's Avatar
mine does it.
seems worse if your seat is already reclined and you try to tip it forward to access the rear.
I think its one of those things you need to live with.
