Water leaks
Old May 7, 2004 | 01:49 AM
bad97f150's Avatar
Water leaks
I have a problem with my 97 F150, lately I find the carpet wet on the passenger side floor. I can't seem to find where the water is coming from. HELP
Old May 7, 2004 | 03:16 PM
max mitchell's Avatar
Welcome ! Just an idea....That's a common place to find wet carpeting from a heater core leak. Are you missing antifreeze? Is it sticky? Do you have a haze on your windows?
Old May 12, 2004 | 10:59 AM
bad97f150's Avatar
The water is not sticky and the coolant level ok. The water is clear.
Old May 12, 2004 | 01:30 PM
Has it just started since air conditioner weather started? After you drive around with the AC on and then park are you getting a consistent AC condensation drainage spot under the truck? That's also a common spot for a clogged AC drain to back up and leak.
Old May 12, 2004 | 05:00 PM
lees99f150's Avatar
ive seen the drain hoses block up where they hang under the truck causing the condensation to back up
