Removing Rear Seat Back on Ext Cab
Old Mar 3, 2003 | 01:08 PM
BikeHauler's Avatar
Anyone know how to remove the seat back (the vertical portion of seat) on a 2000 Extended Cab? Seems like I read somewhere you just pull up. Is this true? Any answers, advice, would be appreciated. I am planning on applying some sound deadening material to the area behind the seat, since it's just painted metal, no insulation, etc.
Old Mar 3, 2003 | 09:32 PM
rtroha's Avatar
There's a couple of little U shaped wires on the bottom of the seat back that I think you have to push towards the back of the cab to disengage. After you do that all you have to do is lift and the seatback will come right out. I'm doing this from memory so I might be a little off but I know it doesn't take any tools and it only takes a couple minutes. Let me know if the deadening makes a difference. I did my 4 doors but I didn't do the back of the cab. I think I'm going to in the spring if it ever gets warm here! Good luck.
Bob
Old Mar 3, 2003 | 09:36 PM
Harley#356's Avatar
I've had my truck for 2 1/2 years now, and i STILL can't find a way to get the seat back out i just want to take it out just to see whats all back there i still can't figure it out though
Old Mar 4, 2003 | 07:52 PM
kidtriton's Avatar
Theres a few 10mm bolts holding it in with tabs on the bottom of the seat back. Then you can slide it up and out.
Old Mar 5, 2003 | 09:24 PM
rtroha's Avatar
Kidtriton, what year is your truck? I didn't remember any bolts holding my seatback on so I checked my service manual. For a 2000 there's no bolts. Just push the bottom of the seatback in and lift.
Bob
Old Mar 6, 2003 | 06:07 PM
kidtriton's Avatar
well mine is currently a 2002, but ive had 4 97's, 2 98's, 1 00, 4 01's and 3 02's. But honestly, the last truck i ever took a seatback out of was a 97 to get the cd changer out to send it off at work. I know the 97 had bolts, so i guess they changed it sometime after that.
Old Mar 7, 2003 | 12:13 AM
mjhpadi's Avatar
Yeah, there are 2 bolts along the bottom of the seat. You have to lift up the carpet piece to see them. Remove those bolts and then just lift up on the seat back and it comes right out.
Old Mar 7, 2003 | 02:35 PM
pw1981's Avatar
How much space is behind there? or is ther any at all?
Old Mar 8, 2003 | 10:02 AM
kidtriton's Avatar
no space , its a pretty flat seatback against a very flat metal wall, lol.
