2016 F-150 "Bambi" mod??
Old Feb 10, 2017 | 06:56 PM
ex400rocks's Avatar
I know this subject has been beaten to death on the older trucks. But I'm curious if someone has found an easy way to do the Bambi mod on a 2016?? I know on the newer Dodge trucks you can use a tuner to make the fogs stay on with the hi beams. I looked when I installed my SCT x4 and no luck. I'm fairly certain everything is ran by the bcm/pcm so it's not as simple as pulling a relay, bending a tab, and grounding it out.
Or am I wrong??
Old Feb 10, 2017 | 09:04 PM
You could just add a relay pretty easy to do
Old Feb 11, 2017 | 02:08 AM
ex400rocks's Avatar
I suppose so. Was just curious if there is an easier way.
I'm not good with relay pins #'s. Which one would go to what? I'd imagine one that's hot at all time, one to the power side of the fogs, And then have it triggered by the hi beam signal?
