Will LED's in tail lights require flasher unit?
I've read some vehicles turn signals and flashers will not work without a flasher unit. Something about their extremely low current draw.
Anyone have any experience? Do LED's in the tail lights work on 04-08 trucks or does this unit need to be installed? |
Originally Posted by 2008_XL
(Post 5119864)
Anyone have any experience? Do LED's in the tail lights work on 04-08 trucks or does this unit need to be installed? To avoid 'hyperflash', you typically: A) replace the current unit with a Tridon EP-27 solid state unit. OR B) add load resistors to the circuit. However - if you still run incandescents in the front signal, you *may* not need to do anything, since there is adequate load for the stock flasher. Try it and see first. MGD |
Originally Posted by MGDfan
(Post 5119866)
Hi.
To avoid 'hyperflash', you typically: A) replace the current unit with a Tridon EP-27 solid state unit. OR B) add load resistors to the circuit. However - if you still run incandescents in the front signal, you *may* not need to do anything, since there is adequate load for the stock flasher. Try it and see first. MGD I will be keeping incandescent in the front. Just want the entire rear to be led. Reverse, tail, third brake light and cargo. Thank you. |
(Post 5119868)
Hi, thank you as always. Where's the flasher unit located? I'm new to this, as I've always just gone with incandescent.
I will be keeping incandescent in the front. Just want the entire rear to be led. Reverse, tail, third brake light and cargo. Thank you. Location: https://www.f150online.com/forums/el...l-flasher.html Do you have Cruise? Folks have had cruise engagement issues when putting LEDs in the third brake light position. That may require it's own load resistor. MGD |
1 Attachment(s)
(Post 5119869)
Hi.
Location: https://www.f150online.com/forums/el...l-flasher.html Do you have Cruise? Folks have had cruise engagement issues when putting LEDs in the third brake light position. That may require it's own load resistor. MGD I do not have cruse. I've already gone with LED's in the 3rd brake light and cargo. No problems. It's just weird, because obviously, even when the vehicle and lights are off, there's still a very small amount of power going to the sockets which causes the LED's to glow very slightly. I spoke with someone at superbrightleds and they said its normal, and not an issue. Looks weird though, huh? Attachment 39175 |
(Post 5119870)
Thanks for the link, that takes care of that.
I do not have cruse. I've already gone with LED's in the 3rd brake light and cargo. No problems. It's just weird, because obviously, even when the vehicle and lights are off, there's still a very small amount of power going to the sockets which causes the LED's to glow very slightly. I spoke with someone at superbrightleds and they said its normal, and not an issue. Looks weird though, huh? https://i.imgur.com/8FSVk5A.jpg A load resistor will address that too. Question fer y'all - which LED tails are ye contemplating? Reason I ask is, VLEDs usually has Thanksgiving Day sales with a nice discount. Makes the Trition V3's pricing a tad more reasonable. good luck MGD |
(Post 5119871)
I kinda like it, lol.
A load resistor will address that too. Question fer y'all - which LED tails are ye contemplating? Reason I ask is, VLEDs usually has Thanksgiving Day sales with a nice discount. Makes the Trition V3's pricing a tad more reasonable. good luck MGD I'll also check that site, ive been ordering from superbrightleds lately. Thank for for your time and great info. I now know a lot more! |
(Post 5119873)
Ah, always some good info from you! I'll look into the load resistor,however, if this won't cause issues or drain the battery, I probably won't mess with it.
I'll also check that site, ive been ordering from superbrightleds lately. Thank for for your time and great info. I now know a lot more! No problem bud. Always a pleasure chattin' with the most fastidious feller on this site. :) :thumbsup: Check out : http://www.vleds.com/promo - usually has some savings in between seasonal sales. Cheers MGD |
(Post 5119875)
Hey;
No problem bud. Always a pleasure chattin' with the most fastidious feller on this site. :) :thumbsup: Check out : http://www.vleds.com/promo - usually has some savings in between seasonal sales. Cheers MGD And, you're one of the most helpful guys on here. Definitely made this a whole lot easier for me. So thanks again! |
| All times are GMT -4. The time now is 12:50 AM. |
