Light Bar In Rear Window
Old Feb 6, 2014 | 07:51 PM
ozzyy1's Avatar
I have a 2006 F150 Supercab. I am a volunteer firefighter in IL, and want to install this 8 head light bar in my rear window. I would like to put it in the top of the window, but I do not have any experience with removing the headliner or drilling towards the roof.
http://www.cpsauthority.com/index.ph...roducts_id=149
Any suggestions on mounting this are appreciated.
Old Feb 6, 2014 | 08:21 PM
spectragod's Avatar
I would depend on how permanent you want it installed. Is there a reason not to mount it outside the cab?
You may want to consider looking at some of the installs over on E Lightbar.com, there may be a better response to your question there.
Old Feb 7, 2014 | 09:24 AM
ozzyy1's Avatar
It would be a permanent mount. I want to keep it inside to keep it out of the IL weather and for simplicity in wiring.
I went to that forum and found some good ideas. Thanks for the help.
I am going to try to make a braket out of aluminum that will go across the back of the cab at the top. From pillar to pillar and screw it in the sides of the pillars.
