Different Hyperflash Issue
Old Dec 28, 2013 | 11:11 AM
il_duce's Avatar
So I recently installed some LED lights in my front turn signals. I already knew of the hyperflash issue from my previous ride so I ordered the resistors to go with them. I got everything from superbrightleds.com. Anyway, I put in both lights first to test to make sure hyperflash was going to be an issue. The left blinker had and still has no issues without a resistor. The right blinker immediately had the issue so I installed the resistor. The hyperflash went away...kind of. It's been about 1 1/2 weeks since I installed them and the left blinker still has no issues even without the resistor. The right blinker picks and chooses when it wants to have issues. I'd say about 20% of the time, it works just fine. The other 80% of the time it has hyperflash. So I'm wondering if I need to install the resistor on the other blinker as well? Or if the issue could be elsewhere. Any ideas? Thanks!
Old Dec 28, 2013 | 07:38 PM
thelariat02's Avatar
Change the blinker relay under the dash with a trailering relay. You can get one from autozone for like ten bucks. Its called a trident 29 just don't remember the number exactly. Search hyperflash.
This relay fixed my hyperflash when I went with LEDs.
Old Dec 28, 2013 | 07:48 PM
il_duce's Avatar
I'll have to look into that more. For some reason I thought I read somewhere on here that the 09's and up no longer had the relay. Something about it all being controlled from the computer now.
Old Dec 28, 2013 | 07:51 PM
il_duce's Avatar
I'm thinking about just going with the one's from superbrightleds that have the built in resistors and be done with it. Not sure if they have a good reputation or not (the lights, not the brand).
Old Dec 28, 2013 | 09:53 PM
Oops sorry didn't know you were 09+ on the app I cant read sigs or info. I believe you are right about there being no relay.
Old Jan 6, 2014 | 10:23 PM
il_duce's Avatar
By the way, I ended up going with superbrightleds.com's 3157s with the built in resistors.
For anyone that is interested, this DOES solve the hyperflash issue. At least in my 2013 F150. I have even ordered 4 more for my tails. Certainly worth the money to not have to deal with wiring and mounting external resistors.
