Interior and Exterior Led Install 2011
Old Jul 2, 2013 | 10:44 PM
Matt60's Avatar
This is a how to change your interior and exterior lights. I will focus on the map lights because they are the only ones that could cause you some problems.
First I took off the clear cover that goes over both lights. Be careful when taking this off, the side closes to the windshield will come off first.
Next you can push the whole assembly towards the windshield and the two clips on either side will come out. This picture is just to show the clips the clear cover should be off this was taken when I was putting it back in.
Then disconnect the lights and the rear window switch to make it easier to work with.
Old Jul 2, 2013 | 11:42 PM
Matt60's Avatar
After you have it out you need to take the metal reflector in order to take the lights out. There are two small white posts in the corners that hold the reflector, I used a small flathead to lift it up. Just be easy because it is easy to bend.
After the reflector is off the lights just simply pop out and the new ones will plug in. At this point it is a good idea to plug the lights back in to see if they work because they only work one way. If they don't work just flip them around and they should work. There are two white cylinder looking things right below the lights that you push to turn the lights on and off.
To reinstall put the reflector back on and put the assembly back in. Once you have it back in half way then you can put the clear lenses back on. Then the side closest to the windshield will go in first. Just go slow and work with it until it is back in. This is the worst part it can get frustrating.
Old Jul 2, 2013 | 11:51 PM
Matt60's Avatar
Rest of the lights are much easier to do and if anyone wants I can post pics of that but I thank y'all can figure those out.
Before
After
Old Jul 3, 2013 | 12:48 AM
Matt60's Avatar
I bought all these lights off ebay for around 30 bucks. I dont know if they will hold up but thet were alot cheeper that superbrightleds so I gave them a try. I will update how they hold up and if they are worth it.
4x T10 7 LED for map light and license plate
2x T10 27 LED for third light
2x T10 65 LED for reverse light
3x Festoon 16 LED 42mm for dome light
Old Jul 3, 2013 | 03:16 AM
camopaint0707's Avatar
looks good
