Aux lights only come on with highbeams
Well I installed the LightForce HID 210 Genesis'. I followed the instructions in the link below and the lights only come on with the high beams. I'm guessing the tee-tap portion is the power supply and the instructions say to tee-tap into high beam wire. Where can I tee-tap so I can turn the Aux lights on whenever I want?
Also is there a certain way I should break these lights in?
http://www.lightforceusa.com/files/p...ober12_web.pdf
Don't rapidly turn them on and off, it's not good for them. And you'll need to tap into somewhere that's always hot, so if your relay is in the engine compartment you can get like a 1-2 amp fuse and do a wire from the battery to the switch pin on the relay.
