2004 F150 Lowbeams not working
Old Jun 14, 2013 | 07:35 PM
Ranchpig's Avatar
This is the "late" model (same as 2005-2008) style lariat w/ DRL and Auto lights.
Problem: Low Beams only not working
Checked so far:
1. No power to fuses 23/25 ... tested fuse in on top of posts.
2. Fuse 40 good to BSM - Pulled out and nothing from light switch works
3. Pulled out the MFS and checked circuit 15 in harness (Red/Ye) and have 10+ volts.
4. Hi Beams / Fog / Marker all work fine
I'm assuming it's my MFS switch. What can i "jump" to determine it's definitely the MFS before I shell out $100?
I've checked all the other answers here, especially from SSCULLY and I cannot determine based on previous answers.
Thanks in advance.
Old Jun 15, 2013 | 09:40 AM
SSCULLY's Avatar
1. when you tested fuses #23 & #25 did you have the main headlamp switch in the on position ( not autolamp ) ?
2. When you are having the issue with the low beams, is it in the on or autolamp position ?
Old Jun 15, 2013 | 02:50 PM
Ranchpig's Avatar
1. yes it was in the On position 2. It is actually both. Primarily, i have only been using the headlamp switch in the ON position (#1 in your diagrams) for diagnosing.
Old Jun 15, 2013 | 03:09 PM
Ranchpig's Avatar
By the way... somehow i missed one of your posts (aha!!) and I just jumped the Red/Yellow and the Red/Black wires on the MFS connector and the low beams do infact work now when Headlight switch is in ON position. It's too bright to try the autolamp.
Old Jun 16, 2013 | 09:35 AM
SSCULLY's Avatar
That is a strong indication that the MFS is the issue.
Time to pull the MFS and test the MFS itself to make sure it is not a connector issue.
Old Jun 16, 2013 | 11:08 PM
Ranchpig's Avatar
You're awesome.... it's the culprit and and i ordered one from parts geek for $75 ... should be here in a few days. I'll put it in and keep the fingers crossed.
BTW: What book are you getting these diagrams from?
Old Sep 7, 2015 | 09:53 PM
Chad Eller's Avatar
Having the same issue, but when I jumped the two wires, nothing. Where is the next thing I should check?
