Rear fog lights and switches
Old Aug 7, 2011 | 05:41 PM
hardrock3742's Avatar
Well I finally got it done. the lights are hidden from behind at eye level so even if it is illegal I dont have to worry about it. I drilled the holes a little too narrow in the panel so it doesnt close all the way and they tend to lean if I hit them but ill just live with it for now. anyone know where I could get a replacement part? just the piece with the cig lighter that pops out.
I grounded the lights on the back of the frame where I mounted them.
Once it gets dark ill adjust the lights more and take some pics.
oh and the lights had a piece of dull metal inside that blocked half of the light( im guessing to make them have more of a beam than a spread) and I took them out so hopefully they will work a little better.
I had to extend both my source and my power wires.
for all of my wire connections outside of the truck I used heat-shrink wrap and then covered it with electrical tape
Old Aug 7, 2011 | 05:52 PM
poolboy1191's Avatar
I like where you mounted the lights. I'm gettin ready to mount mine... Probably will do it in the same spot..
Old Aug 7, 2011 | 06:11 PM
thanks man. I originally had them where they were visible and they looked great there but I decided to move them jst to be safe. I hope they provide enough light
Old Aug 7, 2011 | 07:14 PM
I was thinking about getting this next... http://www.tadibrothers.com/Products/View/SKU34181 I wish I could get it for less money
Old Aug 7, 2011 | 07:28 PM
JackedUp99's Avatar
Nice work.
Old Aug 7, 2011 | 07:36 PM
well now my car wont start. the lights are still working but when I turn the key it makes a weird fast clicking/grinding noise and then when I turn it off my needles shake.???
edit: now its not even making the noise.
Old Aug 7, 2011 | 08:42 PM
Grab a new battery tester and see what your reading...
Old Aug 7, 2011 | 09:02 PM
jumped it and it starts...PHEW! cant wait till it gets dark so I can adjust the fogs and take pics. Im actually kinda worried they wont be bright enough
Old Aug 7, 2011 | 09:11 PM
atr04screw's Avatar
Looks good. Does each switch operate only one light? Or is there one switch for both lights and the other switch is for something else?
Old Aug 7, 2011 | 09:25 PM
one switch for both lights. I put in 2 because I plan on getting a bull bar with 2 more lights in the front.
as it gets darker I keep testing the lights...I think I like them better without the lenses lol. I really hope they are bright enough...If not ill just keep my existing wireing and just get new lights. would that be a bad idea? like if I hooked up more powerful lights to the exisig wiring would it blow the fuse the projectors came with? or would it burn up the wires? stuff like that. I can already tell these arent going to be bright enough :/
Old Aug 7, 2011 | 09:30 PM
atr04screw's Avatar
The lense should help focus the light. If you decide to get new lights then the existing wiring will work fine.
Old Aug 7, 2011 | 09:34 PM
Lol I think im gunna drive up to the store real quick.
Old Aug 7, 2011 | 09:58 PM
Carolinaboy32's Avatar
post up some pics when you can. I am planning on doing this soon
Old Aug 7, 2011 | 10:01 PM
NIGHT PHOTOS
left side is with the lense, right side is without lense.
Unfortunately I like it a lot better without the lense. Its perfect for lighting up the dark spots in my mirrors when im backing up. I wish I could just seal off the lights without the lenses. I guess im gunna run up to the store and get different lights that ARENT projectors. I figures with such a big lense they would be brighter...im dumb lol.
In the defense of the projectors I did not mount them on a flat surface so their full potential was not used. but I still want a more round spread like the light without the lense.
IM gunna run up to walmart and but a different type. lol I hate waiting
Old Aug 7, 2011 | 10:06 PM
Let me know what you get. I want to do the hidden mount like you did. I just want to make sure the lights are bright enough
