A/c clutch squeals? is it possible?
Old Nov 5, 2001 | 05:09 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
I just started having a belt squeal, but after closer investigation it sounds like a metallic sound. I sprayed a little WD-40 style spray where the clutch assembly is( being careful not to hit the belt) and the squealing stopped cold!
Do a/c clutch assemblies squeal before they fail? I have not noticed any degradation in cooling, but the temps are cooler outside now. If anyone still reads this forum, please help if you can.,,,,,98
Old Nov 5, 2001 | 06:36 PM
svtoby150's Avatar
isn't that a bad thing to do?...that is a clutch that works off friction. sounds like that could be it though
Old Nov 5, 2001 | 07:21 PM
98SCREAMER's Avatar
Thumbs up
Well, if it's squealing like a stuck pig, then I probably couldn't do that much harm to it Tightening the acc. bolts didn't help like it did the last time it was making a racket. I just shot a short burst where the pulley contacts the clutch, and the noise stopped. It's going in to the dealer thursday, just wanted some possible solutions or suggestions to give them.,,,,,98
The compressor is about two years old, was a part of the assemblies replaced when I bought the truck. maybe the tensioner is gone again?
