Loosing my mind
Loosing my mind
As the title states Im Loosing my mind with my truck ac
I have a 06 f150 and after having my ac compressor swapped out after hearing a clattering sound it stop completely working.
Soo far I've changed with only brand new parts are following
Compressor
Condensor
Drier
Low pressure switch
High pressure switch
Office tube
My current symptoms Im having is the compressor is short cycling and it will stay on for 2 sec and off for 5 sec than on again
My low pressure side seems to be good on the gauge
has mfg recommended amount inside
I've taken it to 3 different shops and its something no one can figure out
we tried jumping switch connectors the compressor will stay on but no cold air
We tried jumping relay
Compressor
Condensor
Drier
Low pressure switch
Office tube
What are the pressure readings low and high pressure at idle and with the engine revved and what are they when the compressor shuts off. There may be something plugging the evaporator. Was the system flushed after the compressor failed?
