Finicky ac
Finicky ac
I have a 2007 f150 5.4v flex fuel with 190k miles. For some reason my ac will turn in randomly with or without hitting a bump. Has anyone else dellt with this before or know what the problem is by chance? Thanks
I will be driving without the ac/ heater on and the blower will turn on out of no where. Once it turns on I'll turn the switch on and turn it back to off and it will shut off. It doesnt happen all the time maybe once or twice a month
Check the blower motor resistor, Those have a bad habit of going bad and they're easy to change out. Does these happen at all blower speeds or just some of them?
Let's go back to this statement: "I will be driving without the ac/ heater on and the blower will turn on out of no where." Does that mean that you are driving with the climate mode control switch set to the OFF position, a rather odd choice, I might say? If so, then when "Once it turns on I'll turn the switch on and turn it back to off and it will shut off.", to me that implies that there is an intermittent fault within the climate control panel (EMTC) that is causing activation of the blower motor relay when the switch is set to OFF. When the blower motor does come on, does it come on to the speed that corresponds to the current setting of the blower speed control switch or something else?
For the reason glc noted, that would be impossible.
