Can't Recharge Freon
OK, I went to AutoZone and used their gauges. The ambient temperature was 80 degrees. with the compressor not engaged the pressures read 25 psi L & 150 psi H. When the compressor kicked in, the low side would go up to 50 psi & the high side would drop to about 110 psi.
Any thoughts?
Any thoughts?
I think you just need some more refrigerant. But, it may be best to get a pro to do it. Your learning curve is too steep right now.
