2003 FX4 auto A/C blowing out defrost vent on acceleration
Old Jun 14, 2012 | 10:35 PM
robsxlt's Avatar
Ok, I've looked at other threads on this that I could find and all seem to be that the A/C is stuck on the defrost. Well, mine comes out of the defrost on acceleration but if your on a level road and there is no additional acceleration it works like it's supposed to. But, if you go up a hill or speed up then it switches to the defrost. Any ideas?? Thanks for the help!!
Old Jun 14, 2012 | 10:41 PM
vacuum leak on the AC system, check on the firewall near the battery first
there should be a plastic vacuum reservoir tucked behind the battery in the fender, follow the plastic vacuum lines going into the firewall.
Do you have "digital air" or mechanical twist *****?
Old Jun 15, 2012 | 05:55 PM
robsxlt's Avatar
Digital air. I'm going to check the vacuum tube tomorrow but this has not been pleasant. Living in Alabama in the summer has it's drawbacks!
Old Jun 15, 2012 | 07:15 PM
I would start with looking for a leak in the main vacuum system
you might have a leak in the AC control head too, you can rebuild the head by putting new Orings in it.
Old Jun 17, 2012 | 07:42 PM
robsxlt's Avatar
Well, replacing the O-rings did the trick. It took about 30 mins, one of the easiest things I've done to this truck! Thanks for the help!!
Old Jun 17, 2012 | 10:45 PM
glad you got it!
Old Jun 18, 2012 | 09:36 PM
ToryT's Avatar
I have the same problem with my truck. Where did you get the o-rings and where are they located on the truck? Thanks
Old Jun 18, 2012 | 09:47 PM
inside the control head itself
link: https://www.f150online.com/forums/hv...buildable.html
Old Jul 10, 2012 | 05:34 PM
fish2412's Avatar
hey my mom has the same problem with her 01 windstar but she has control ***** not digital what could it be and where do I find the control head it that van thx for your help
Old Jul 16, 2012 | 03:01 PM
IR0NS1N's Avatar
Control head is the part that you adjust mode / air temp, It has vacuum lines going to the back of it.
