92 f150 a/c relay switch
Old Mar 20, 2012 | 10:54 AM
busterray's Avatar
Does anyone know where the a/c compressor relay switch is located on 1992 f150?
Old Jun 22, 2012 | 10:01 AM
FiddyCent's Avatar
Look on the Pass side under the hood near the fire wall. It is in the side of the accumulator ( long black cylinder ). You can unplug it and jump the connector to see if your compressor will kick on.
Old Jun 22, 2012 | 06:17 PM
projectSHO89's Avatar
Your truck doesn't use an "a/c relay switch".... It uses a simple pressure cycling switch to control the compressor clutch.
