Blend door or compressor?
Old Jul 7, 2011 | 06:36 AM
RegLiner's Avatar
Seems I have issues similar to everyone else, but I'm beating my brains out because I can't nail it down.
I have an 07 Screw with manual climate controls. I know my blend door is bad and I have an actuator, just haven't changed it yet. My A/C compressor clutch doesn't engage. I've check the relay, fuses and shot the wires and can't find a problem. I hooked gauges up and have a charge, can't find any leaks.
Will changing the blend door actuator fix this or do I have 2 problems?
Old Jul 7, 2011 | 07:00 AM
projectSHO89's Avatar
Two problems. The actuator has nothing to do with the clutch and vice versa.
What was your system's static pressure?
Old Jul 8, 2011 | 04:28 AM
RegLiner's Avatar
I assumed I had 2 problems, but wasn't sure if there was logic between the actuator and compressor
I do not remember the exact reading right now. I do remember it being in the red on the gauge. It was just your typical gauge you get with a can of refrigerant at any auto parts store.
