2002 A/C is possesed..
Ok, i just had to drive back to Florida and home again last week. On the way back, i noticed when i would accelerate, the a/c would start blowing out of the defrost only, not the vents. Did this on MAX a/c and the regular setting. The truck is a Lariat and has the automatic a/c controls, not the *****. I thought i remember reading about some small o-rings located inside the control unit that go bad and can be replaced for a few doallars and time. Anyone know anything about that, or am i having another flashback?
Thanks!
Thanks!
Where are the vacuum lines in the engine compartment? I have not had a chance to look too close yet. It seems to work fine around town yesterday and today.. kind of an intermittent thing. Where can you buy the control units? I looked on RockAuto yesterday just to get an idea if i can't fix it by replacing o-rings, didn't see anything. Thanks for the response, projectSHO89.
I had the same problem with my 93 F-150, it was the vac valve that controls the defrost flapper door. There is a hard plastic vac line that plugs into the vac valve; it was dry rotten/ cracked near the valve. I bought a 1 foot long piece of vac hose (.75 cents) to replace the length I cut off. Problem fixed. The vac valve on my 93 was on the fire wall on pass side. Hope this helps
