How to change accumulator?
Old Sep 16, 2010 | 06:46 PM
Patrick Shady's Avatar
Hello everyone i have a quick question on how to change out the accumulator on a 2005 scab. The original accumulator received a hole from rubbing and i lost the charge. One side has a bolt and O ring and the other goes straight into the evap and is the piping in question. Any infromation will help, thanks a lot guys.
Old Sep 19, 2010 | 12:28 PM
Well it was worth a shot but i figured it was too technical of a question for this forum.
Old Sep 21, 2010 | 01:02 AM
jethat's Avatar
not many around here do there own A/C repairs. I'd just get the Chilton or Hayes book and follow the instructions. Then I'd recharge it. Cant be that hard.
Old Sep 22, 2010 | 06:53 PM
V1Ranch's Avatar
Remove the PCM Module, then the battery and battery tray. Remove the PCM bracket. Disconnect the Inlet/Outlet fitting nuts on the Accumulator. Discard the o-rings. Installation is reverse. Inlet is 8Nm(71 lb-in), Outlet is 9Nm (80 lb-in). I would check the evaporator core orifice for any debris/metal. If you find any metal, your compressor is shot. I have to do my compressor, accumulator, and core orifice next week, so I'll try to take some pics for a how-to.
Hope this helps!
Remember: Beer always makes this a much calmer process...
DT
Old Sep 23, 2010 | 05:47 PM
I wish it was that easy. I do commercial AC for a living so I hate to do but I guess I'll end up taking it to an AC shop.
Old Sep 24, 2010 | 12:03 PM
zziggy's Avatar
That is a spring lock fitting at the evaporator.
The Spring Lock removal tools can be rented or purchased at most any quality auto parts store.
Old Sep 25, 2010 | 06:45 PM
you are the man
