Blower Motor?
Old Oct 9, 2000 | 10:40 PM
freefall's Avatar
Question Blower Motor?
Have a 1977 F-1560 Ranger. Heater Blower Motor went out and can't figure out how to replace it. ANy ideas.
Old Oct 9, 2000 | 11:23 PM
nitro94's Avatar
Post
If I have this pictured right it is a hole lot of fun. Been there several times. This has a large box on the right firewall that covers up most of the right head, correct? If so the blower comes out from under the dash. Remove a large panel behind glove box. You will be able to see the evaparator core. Remove that. you will see the heater core. Remove that. You will see a blend air door. Remove that. Finally the blower motor. If you are not mechanically inclined don't try it otherwise go slow and good luck.
2000 XLT Bright red, Flareside,extended cab,sport,5.4,bedrug,Extang tonneau.
Old Oct 10, 2000 | 01:38 AM
freefall's Avatar
Unhappy
Bummer, I thought that was the routine. As you can see I'm in ALaska and heater's are important here. Thanks for clarifying that for me.
Danny
