Where to set knob?
Where does everyone leave there selector **** for the heater/defroster etc... In my owners manual, it says to leave it on anything but off, to let the system "breath", Is this what everyone does. I usually turn it to the OFF position everytime I get out of my truck. Should I leave it on a different setting for some other reason? I have a 98 f-150.
You should leave it in any position other than Off and Max A/C. Those two positions close off the vents to the outside.
If you use your a/c or heater, there's no reason to ever set the switch to off.
[This message has been edited by Dennis (edited 08-27-2000).]
I usually leave mine in the PANEL position for that very reason.
2000 F-150 XLT, 4x2, 5.4L Supercab, LEV, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil and filter, Build date 7/00
- Factory cab steps on order
Even with the windows down?
-AR
- 2001 F-150 XLT 4X4 Off-Road, S/C, FS, Black
- 4.6L Triton V8 (20 H.P. Increase)
- 5 Speed / 3:55 Reg. Axle
- Keyless
- Premium Audio CD
- Mods.
- K&N Cold Air mod.
- Flowmaster 40 (Stock Setup with 3 1/2" Gibson Tip)
- Bugshield
- Bedliner
- Ventshades
-AR
- Keyless
- Premium Audio CD
- Mods.
- K&N Cold Air mod.
- Bugshield
- Bedliner
- Ventshades
Defrost. Lowest fan speed. Temperature set to cold.
Keeps a little ventilation up on the windshield to demist (and we have cooler temps here and have had a lot of rain, so it helps).
But I've always done that. Blows a little fresh, cool air on my face and keeps the AC compressor engaged to keep the seals lubed and soft, so fewer leaks I am told.
Black 2000 SC short-box XLT. 4.2V-6, 5-speed, 3.55 limited-slip. CD, remote entry, factory side steps, FORD box liner.
My third F-series: '73 F-100 Custom 240-cube 3-speed, '98 F-150 XL-SC 4.2 5-speed, and '00 F-150 XLT-SC 4.2 5-speed. GREAT trucks!
D. All of the above.
Shifter, Dennis, and Jackal all have good points.
This could relate the the musty odor from the vents. Just try to allow fresh air through the vents. That's what the manual had in mind.
There's no need to turn it to the OFF position.
Mine stays on FLR/DEF. Even when I race.
BLOWN 4.6 5-speed
Where we started.
After a facelift.
Latest MOD!
Trixters-Playground!
trixters-playground@excite.com
F-150online Photo Album
crash@f150fanatic.com
MAGNACHARGER
ALLEN
BLOWN 4.6 5-speed
Where we started.
After a facelift.
Latest MOD!
MAGNACHARGER
ALLEN
And YES, use the A/C mode or DEFROST in the winter. This will keep oil circulating and will keep the "O" rings lubricated.
If you are cold, turn the temp selector to HOT. The compressor will still run.
