AC compressor clutch issue...HELP!
Ok my truck started making a werid noise the other day and it was diagnosed as the ac compessor clutch...so i let it sit for a couple days and i started this morning...no noise at all...i want to make sure its the clutch how can i tell when theres no noise...are there loose pieces...mine right now has a metal piece thats the second piece back on the cluttch and its loose and i can move it...please help me out i dont want to tale it off if its not necessary.
The only way a 3-jaw puller will work is to put the compressor on your workbench.
Did you test the coil to see if it worked or not? Using a light piece of steel turn on the ac switch and you should have a magnetic pull on the steel. Was your clutch worn out? Was the bearing on the pulley dragging, burnt?
If there's a clearance issue with using a small 3-jaw puller, the solution is to unbolt the compressor from the bracket, but leave the lines connected. I doubt there'd be a real clearance issue though in a full-size truck after removing the fan and shroud.
