Air Conditioner Draining Please Help
Old Jun 1, 2010 | 04:50 PM
ltsingley's Avatar
Exclamation Air Conditioner Draining Please Help
The air conditioner in my 2004 F150 is draining into my passenger floorboard. Its beginning to be a problem. Can someone please tell me where this drain is located, how to get to it, and if you know how to fix it that would be great info too.
Old Jun 1, 2010 | 07:27 PM
Roadie's Avatar
I haven't looked at my truck, but I'm sure the drain line is located just below the firewall. If you crawl under you should see it. On older ford cars, I've run a stiff wire up the drain hose and unplugged it. In fact, my wife recently said she was getting water on her feet, so I need to do this on my truck. This seems to be recurring problem with Fords for several generations.
Old Jun 1, 2010 | 10:02 PM
nate136's Avatar
http://ww2.justanswer.com/uploads/fo...SB_07-13-5.pdf
Did this to mine couple months ago and it worked.. no more leak!! hope this helps
Old Sep 8, 2010 | 03:40 PM
Wade06XLT's Avatar
Once again: Google and F150online are your friends.
