??Heating Problems??
Old Mar 5, 2010 | 06:29 PM
RugerShooter's Avatar
I have a 1998 F250 LD 5.4L
The first problem I had was after my truck warmed (about 3 miles) up the gauge would stay right in the middle where it should and blow warm, but when I stop and idle my truck the heat goes cold, (gauge stayed normal). So I replaced the Water Pump & thermostat.
That didn't fix the problem, only made it worse. Now my gauge stays at the Cold for about 5 miles then shoots up to HOT instantly and the check gauge light comes on for about 30 seconds, then falls to normal for about 1-2 min than to cold. Then again it shoots back to hot and then falls to normal and stays there.
I also have burped the air out of the system, and think I have all the air out of the system. I did this by squeezing the top radiator hose while the engine is running and circulating coolant.
Any ideas of where to look next?
Old Mar 6, 2010 | 10:58 PM
torkum's Avatar
Have you checked the 2 heater hoses going into the firewall? They both should be equally hot, if not the heater core could be clogged.
Old Mar 7, 2010 | 09:34 PM
ya I did, they are the same temp. I took it to a friend this weekend, and he is almost positive it's a head gasket. The anitfreeze smells of exhaust and a lot of air bubbles are bubbling when the engine is hot and running.
Old Mar 9, 2010 | 07:25 AM
10thGenF150's Avatar
All the signs of a blown headgasket. Did he do a leak down test or pressure test?
