ac coolant refill
Old Apr 30, 2009 | 09:27 PM
biga9905's Avatar
ac coolant refill
i have a 2002 f 150. where exactly is the low pressure port and do i have to buy a specific kind of coolant. im getting the kind that has the attachment on the bottle to refill it with.
Old May 2, 2009 | 10:42 AM
R8rvectors's Avatar
If it's similar to my '99, look for a silvery canister mounted vertically on the passenger side firewall. The low pressure port faces forward and has a black cover that unscrews. I believe 134a is the gas you need. Use a kit with a gauge (don't overfill) and follow the directions.
Old May 2, 2009 | 08:17 PM
Steve83's Avatar
Don't put coolant in the A/C system. Coolant goes in the engine; refrigerant goes in the A/C.
Don't add refrigerant with a straight hose. It takes a manifold gauge set to know IF the system needs more refrigerant, and if so, how MUCH to add.
Take it to a pro.
