ac compressor pulley
Old Jan 4, 2009 | 07:35 PM
bmxrider5x's Avatar
hi, today my ac compressor pulley started making a awful howling scratching sound. so i went underneath and comes to find out one of those plastic caps is missing on the pulley itself. they are in a triangle pattern. and its letting that metal ring ride against the compressor. question is does anyone know where i can just find that cap or just replace the pulley itself thanks.
Old Jan 5, 2009 | 11:03 AM
projectSHO89's Avatar
You need, at a minimum, a new pressure plate. Get it from Ford.
Do not delay in removing the old pressure plate. Waiting too long may contribute to premature failure of the pulley bearing.
Remove the bolt, gently pry off the plate, and do not loose the shim(s) that are between the snout of the hub and the face of the shaft.
Steve
Old Jan 5, 2009 | 09:01 PM
bmxrider5x's Avatar
ok kool, the bolt is only the small one in the center correct?
Old Jan 7, 2009 | 07:33 PM
bmxrider5x's Avatar
i was thinkin about just gettin a new compressor but in the mean time get a bypass pulley and not have ac for awhile. would i need to do anything besides just put the pulley on, like plugs or anything thanks
Old Jan 8, 2009 | 07:50 AM
jhartley's Avatar
Why would you do that? on my 04 I lost the pressure plate going down the road. all you have to do is remove the center bolt and remove the pressure plate the pulley is held on by a snap ring on the compressor. i drove like that for a moth with out a pressure plate. Memory serves me right a pressure plate cost about $35. just make shure that you dont loose the shims behind the plate they cost around $19 for a bag of 5
Old Jan 8, 2009 | 01:36 PM
bmxrider5x's Avatar
ok i'll go take it off and just run like that for awhile thanks for the help
Old Jan 25, 2009 | 11:05 PM
bmxrider5x's Avatar
hey guys i need some help today i was leavin for work and my pulley for my ac froze, does anyone know how long of a belt do i need to just bypass it for now . would i have to get a delete pulley or wat im lost
