no heat
Old Nov 3, 2008 | 09:16 PM
LB23's Avatar
no heat
97 f150 xlt 4.6l just replaced thermostat still have no heat
Old Nov 3, 2008 | 09:23 PM
heater core is probably clogged.
or do you mean that the engine temp gauge shows colder then normal operating range?
Old Nov 6, 2008 | 09:11 PM
LB23's Avatar
temp gage is fine shows proper reading how do you unclog the heater core?
Old Nov 6, 2008 | 09:46 PM
usually you get to replace it, which means you get to remove the dash. Its between the firewall and the front face of the dash.
I would take it somewhere and have them look at it tho, dont trust my E-Diagnosis 100% :o
Old Nov 8, 2008 | 09:42 AM
LB23's Avatar
thanks for the info will get it checked
Old Nov 17, 2008 | 11:26 AM
flbuilder1's Avatar
I have the same problem with my 2000 5.4. Can I use pressure to try to force water through the core?
