HELP! My blower motor will not come on. 2006 F150
Old Oct 16, 2008 | 12:21 PM
Nagyb's Avatar
I have a 2006 F150 with the digital a/c control module. The blower motor stopped coming on.
I have checked the Relay and Fuse, they are both good. I pulled the motor out and shot 12v to it, it works. I checked for voltage at the 4 pin connector behind the dash, and nada no power.
What should I do next? I read something that said try to reset the EATC, or go into diagnostics... Should I try that?
Old Oct 17, 2008 | 09:01 AM
projectSHO89's Avatar
Have you followed the diagnostic procedure in the Workshop manual?
If you don't have it, let us know so it can be gotten to you.
Steve
Old Oct 17, 2008 | 10:54 PM
Nagyb's Avatar
I have done the diagnostic, I am sure it is the digital control module.
I would like to have the workshop manual if you have it handy. Thanks!
Old Oct 18, 2008 | 07:20 AM
Grab these two files which are relevant excerpts from the manual:
http://www.mediafire.com/?3j23s2s9cm1
http://www.mediafire.com/?j0tbcmh35z2
You'll probably need to use Pinpoint test N.
Steve
