HVAC problem
Old Aug 11, 2008 | 09:00 PM
rvdealer's Avatar
HVAC problem
I have 2002 f150 King Ranch form day one the A/C and heater control have never worked right, it has the electronic system in it where you set the temp on on A/C whatever you want and the same with the heat I live in FL
so the A/C is on max most of the time but in the winter the heat only works when you dial it all the way up to 90
if you run it down to 85 the heat goes completely off nothing but cold air. I have had it back to the dealer 3-4 times they can't figure it out! This truck has done this since the day it was new they switch the control inside and it did'nt change anything the said thats just how it works!
I have several friends with the same system and theres works great any sugestions
Old Aug 12, 2008 | 07:45 AM
projectSHO89's Avatar
Take it to a different dealer.
Steve
