smells like mold or something please help
Old Jul 1, 2008 | 02:58 AM
grayruckus's Avatar
i have a 07 supercrew 5.4 and when i turn my ac on it smells like mold or something i was just wondering if its the cabin air filter...do i have a cabin air filter and how can i get to it. please help...thanks
Old Jul 1, 2008 | 03:15 AM
Paralyzer's Avatar
no u do not have a cabin air filter. there is however a drain on the firewall to let moisture in the hvac system to drain out. if this hole is plugged water may be trapped in there. other then that the best thing i can suggest is get the truck hot, roll down the windows and blast the heat for an hour or so. that will get the moisture out of the system.
Old Jul 1, 2008 | 03:35 AM
grayruckus's Avatar
thanks alot ill try that
Old Jul 1, 2008 | 03:40 AM
grayruckus's Avatar
im sorry...but where exactly is that drain?
Old Jul 1, 2008 | 04:42 AM
Paralyzer's Avatar
i dont know the exact location but it should be on the passenger side about 3/4 of the way down. chances are you will only see it from under the truck. if you can see water driping on the ground after driving around with the A/C on for a while its not plugged also.
Old Jul 1, 2008 | 01:37 PM
grayruckus's Avatar
thanks once again
