AC won't come on Right away???
Old Apr 27, 2008 | 03:43 PM
jjltexas's Avatar
Cool AC won't come on Right away???
I have a 2003 F150, when I first turn on my AC it some times takes 3 0r 4 minuets to come on, it don't do it all the time ,but here lately it's been doing it more often.Once the AC comes on it works just fine.
Old May 9, 2008 | 06:31 AM
torkum's Avatar
Do you have the Auto temp control like in the pic ? If so, may be a problem with control unit.
Old May 15, 2008 | 07:37 AM
my05fx4's Avatar
I have the same problem with my 05!!! But mine is not automatic climate but is the rotary **** type. Does ANYBODY know what can be causing this??? It must not happen too often bc I have posted this problem twice before and I got no responses from anyone in this fine forum! I guess I'm not the only one. Any ideas folks?????
Old May 17, 2008 | 03:28 AM
warrantyvoider's Avatar
first step could be to just check your charge. thats the easiest thing to test.
Old May 23, 2008 | 08:33 PM
Ballin STX's Avatar
what do you mean check your charge?
Old May 25, 2008 | 01:37 AM
transam396's Avatar
what they mean by check the charge is to take it and have the ammount of freon checked.
My 04 F150 was not cooling properly so i had it checked and it was low when i got there it was cooling at 53 degree's, By the time i left it was at 43 and dropping.
If the charge is low i bellieve there is a switch that will stop it from coming on. it might be right at the limit
Old May 25, 2008 | 03:00 AM
Ballin STX's Avatar
thanks for the info man, I really apprechiate that.
